This is quite an interesting thing I noticed, for instance:
  • I use Atom Editor and I call it via my Terminal using:
    $ atom
    and press Enter, which triggers the Editor and also make the terminal cursor point to the new line; making it (Terminal) free for further command line utilities.
  • However, when in use RhythmBox using rhythmbox as terminal command, it tends to work on the foreground (I guess) and keeps the terminal occupied till I close Rhythmbox or use CTRL+C.
I tried this with texmaker too and it performs similar thing as Rhythmbox. I know that & will take the process on the background but is there a logical explanation for some applications as mentioned here?
Any hacks or tips so that I can learn how to tweak things like this?
Note
I try using CTRL+Z on the above mentioned applications and the apps then gray out and become unresponsive and I have to force quit on them
Environment
  • Using Ubuntu 16.10
  • Gnome Terminal
  • echo $SHELL give /bin/bash
muru
  • 207,228
As has been pointed out in the comments, such behavior is specific to each application. Applications written in C programming language, for example, can employ setsid call to disconnect from controlling terminal, although they require call to fork() syscall first. Python, also has os.setsid() and os.fork() functions; although it is possible to simply use os.fork() to create a child process and kill the parent.
Another very frequent technique that software authors use is launching applications via wrapper script, and calling a new process via nohup. That's exactly what atom does:
$ file $(which atom)
/usr/bin/atom: Bourne-Again shell script, ASCII text executable
$ grep 'nohup' $(which atom)
    nohup "$ATOM_PATH" --executed-from="$(pwd)" --pid=$$ "$@" > "$ATOM_HOME/nohup.out" 2>&1
      cat "$ATOM_HOME/nohup.out"
You can do so as well. For instance, the way I tend to launch programs and detach them from terminal is via a function, that launches desired program with nohup already appended to the command:
runstuff() {
    nohup "$@" >/dev/null 2>&1 &
Once you define that in your .bashrc , you can launch firefox like so :
runstuff firefox
Another way, is via setsid command (which is named same as the C system call, but is actually a standalone binary):
setsid firefox
If you use Ubuntu with X environemnt you can push Ctrl + F2 and then put the command you need (i.e. rythmbox). It won't have separate terminal where you can push ctrl+C.
You can also try to run nohup rythmbox &. It should run your player in backgroud and make it terminal-close-proof.
Kamil
  • 646
