I get this whenever I try to install a package
$ sudo apt-get install metacity
Reading package lists... Done
Building dependency tree
Suggested packages:
  gnome-control-center
The following NEW packages will be installed:
  metacity
0 upgraded, 1 newly installed, 0 to remove and 157 not upgraded.
1 not fully installed or removed.
Need to get 0 B/243 kB of archives.
After this operation, 744 kB of additional disk space will be used.
I tried the basic fixes, didn't work.
sudo apt-get clean && sudo apt-get autoremove
sudo apt-get -f install
sudo dpkg --configure -a
This is what I get when I do an apt download
$ sudo apt download metacity
Get:1 http://in.archive.ubuntu.com/ubuntu xenial/main amd64 metacity amd64 1:3.18.3-1ubuntu3 [243 kB]
Fetched 243 kB in 2s (90.4 kB/s)
W: Can't drop privileges for downloading as file '/home/jaison/metacity_1%3a3.18.3-1ubuntu3_amd64.deb' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
wjandrea
  • 14,504
Try:
sudo apt-get clean
sudo apt-get clean all
sudo apt-get update
sudo apt-get upgrade
Then try installing the package you want. If it still fails, post new error.
edit:
also, if you want to download the the .deb, don't use sudo. Just run:
apt-get download metacity
that will fix the permission issue. When you try to download using sudo, the account that actually downloads the file is "_apt" and _apt does not have permission to write in your home directory.
James
  • 1,103
