How can I download, install and open Anydesk? From the homepage of Anydesk to the Software Center of Ubuntu and installation / download everything is fine but then I couldn't open it.
Through GUI:
select your os-compatibility version and install through ubuntu-software-center.
Through CLI:
sudo dpkg -i anydesk_2.9.4-1_amd64.debInstall AnyDesk via Ubuntu software center. (Simply open your 'Downloads' folder, right click on
anydesk_2.9.4-1_amd64.debchoose Open With Software Install. Enter your password when it prompted then wait for the AnyDesk installation process to complete.)
Better use their repository as suggested here:
Update as of 22.04 to improve security
obtain root privileges
sudo su
To add the key:
curl -fsSL https://keys.anydesk.com/repos/DEB-GPG-KEY|sudo gpg --dearmor -o /usr/share/keyrings/anydesk.gpg
add the repository:
echo "deb [signed-by=/usr/share/keyrings/anydesk.gpg] http://deb.anydesk.com/ all main" > /etc/apt/sources.list.d/anydesk-stable.list
update apt cache:
apt update
install anydesk:
apt install anydesk
Prior answer involving apt-key
obtain root priviledges
sudo su
add repository key to Trusted software providers list
wget -qO - https://keys.anydesk.com/repos/DEB-GPG-KEY | apt-key add -
add the repository:
echo "deb http://deb.anydesk.com/ all main" > /etc/apt/sources.list.d/anydesk-stable.list
update apt cache:
apt update
install anydesk:
apt install anydesk
- 11,099
Sometimes it does not allow installation from GUI. You can follow below commands:
wget https://download.anydesk.com/linux/anydesk_2.9.6-1_amd64.deb
sudo dpkg -i https://download.anydesk.com/linux/anydesk_2.9.6-1_amd64.deb
Now go to that folder in your terminal and use
sudo apt install ./anydesk_2.9.6-1_amd64.deb
If you have already installed anydesk and want to un-install use bellow command:
sudo apt-get --purge remove anydesk
- 451
Download Anydesk
wget https://download.anydesk.com/linux/anydesk_6.1.0-1_amd64.deb #(may expire)Install AnyDesk
Once the download is done, run the command below to instal AnyDesk.
sudo apt install -y ./anydesk_5.1.0-1_amd64.deb
Once the installation is finished AnyDesk will run by default. You can check the status by running the command below;
systemctl status anydesk.service
● anydesk.service - AnyDesk
Loaded: loaded (/etc/systemd/system/anydesk.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2019-06-11 20:46:50 EAT; 2s ago
Main PID: 4386 (anydesk) Tasks: 12 (limit: 2336)
CGroup: /system.slice/anydesk.service
├─4386 /usr/bin/anydesk --service
└─4389 /usr/bin/anydesk --tray
Wax 11 20:46:50 server01.example.com systemd[1]: Started AnyDesk.
You have successfully installed AnyDesk on Ubuntu 18.04 desktop. You can now connect to your remote desktop smoothly and securely with AnyDesk. Enjoy.
- 187
- 31
- 2
I was getting the following error:
E: Unsupported file ./anydesk_5.1.0-1_amd64.deb given on commandline
The following commands (as root) worked for me:
$ sudo su
$ echo "deb http://deb.anydesk.com/ all main" > /etc/apt/sources.list.d/anydesk-stable.list
$ apt update
$ apt install anydesk
- 16,703
- 831
https://itsfoss.com/install-anydesk-ubuntu/
or
Open the terminal application on your system. You’ll need a tool like wget to download files in the terminal. For that, use the following command:
1- sudo apt update
2- sudo apt install wget
The next step now is to download the GPG key of AnyDesk repository and add it to your system’s trusted keys. This way, your system will trust the software coming from this external repository.
3- wget -qO - https://keys.anydesk.com/repos/DEB-GPG-KEY | sudo apt-key add -
You may ignore the deprecated warning about apt-key command for now. The next step is to add the AnyDesk repository to your system’s repository sources:
4- echo "deb http://deb.anydesk.com/ all main" | sudo tee /etc/apt/sources.list.d/anydesk-stable.list
Update the package cache so that your system learns about the availability of new applications through the newly added repository.
5- sudo apt update
6- sudo apt install anydesk
7- anydesk
- 11
- 2
I use the following code to install.
First, download anydesk from anydesk.com. Then run:
sudo apt --fix-broken install /tmp/mozilla_user/anydesk_5.5.6-1_amd64.deb
Note: Replace /tmp/mozilla_user with your download path.
- 119,640
I have the following error:
dpkg: error processing package anydesk (--install):
that resolved by:
sudo apt --fix-broken install ./andydesk.deb
- 171
Just run this command
Type password and then when it required permission press Y and then tap enter and You are done installing Anydesk
In the first step, you must be a root account *** in UBUNTU
How ?
- Open the terminal with the same account
- Type :
sudo passwd root( and press enter) enter your user password enter your user password again - now type :
su -( and press enter ) - next Type :
wget -qO - https://keys.anydesk.com/repos/DEB-GPG-KEY | apt-key add -5.next Type :echo "deb http://deb.anydesk.com/ all main" > /etc/apt/sources.list.d/anydesk-stable.list - next Type :
apt update - for install enydesk Type :
apt install anydesk
Done! :) have a great day
I had installed anydesk from Ubuntu software. After installation, I opened it in the Ubuntu software itself but couldn't find Run button. Only option shown to me was Remove button. Also had no idea where the runnable file was so couldn't click anything to run. I think this is also the position of OP. I ran below command:
Locate anydesk
It gave me bunch of paths. From which I opened below path in file explorer and double-clicked file anydesk and the app opened.
/usr/bin/anydesk
- 101
- 2
