I am unable to upgrade Ubuntu 14.04 or install any new software as I always get the following error:
You might want to run 'apt-get -f install' to correct these:
libc6-dev : Depends: linux-libc-dev but it is not going to be installed
libnss3 : Breaks: libnss3:i386 (!= 2:3.19.2-1ubuntu1) but 2:3.26.2-0ubuntu0.14.04.3 is to be installed
libnss3:i386 : Breaks: libnss3 (!= 2:3.26.2-0ubuntu0.14.04.3) but 2:3.19.2-1ubuntu1 is to be installed
libnss3-nssdb : Depends: libnss3 (= 2:3.26.2-0ubuntu0.14.04.3) but 2:3.19.2-1ubuntu1 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I tried running
sudo apt-get -f install
but it doesn't work as I get the following error in output:
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
account-plugin-windows-live kde-l10n-ar kde-l10n-engb libntdb1 libupstart1
linux-headers-3.16.0-30 linux-headers-3.16.0-30-generic
linux-image-3.16.0-30-generic linux-image-extra-3.16.0-30-generic
python-ntdb python-pexpect python-renderpm python-reportlab
python-reportlab-accel
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
libnss3
The following packages will be upgraded:
libnss3
1 upgraded, 0 newly installed, 0 to remove and 146 not upgraded.
3 not fully installed or removed.
Need to get 1,126 kB of archives.
After this operation, 30.7 kB disk space will be freed.
Do you want to continue? [Y/n] Y
Get:1 http://archive.ubuntu.com/ubuntu/ trusty-updates/main libnss3 amd64 2:3.26.2-0ubuntu0.14.04.3 [1,126 kB]
Fetched 1,126 kB in 5s (214 kB/s)
(Reading database ... 292354 files and directories currently installed.)
Preparing to unpack .../libnss3_2%3a3.26.2-0ubuntu0.14.04.3_amd64.deb ...
Unpacking libnss3:amd64 (2:3.26.2-0ubuntu0.14.04.3) over (2:3.19.2-1ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/libnss3_2%3a3.26.2-0ubuntu0.14.04.3_amd64.deb (--unpack):
trying to overwrite shared '/usr/share/doc/libnss3/changelog.Debian.gz', which is different from other instances of package libnss3:amd64
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Edit: There is an error icon appearing just next to clock in top status bar, which contains text
An error occurred, please run Package Manager from the right-click menu or apt-get in a terminal to see what is wrong. The error message was: 'Error: Brokencount > 0'. This usually means you installed packages have unmet dependencies.
By clicking on Show Updates in this icon menu I get window (New Important Security and hardware support update.
WARNING: Security updates for your current hardware Enablement stack ended on 2016-08-04 http://wiki.ubuntu.com/1404_HWE_EOL
By trying to click install on this window, it still gives me an error installing.
How can I fix my system so that I can upgrade?
