I tried to install the latest version of Ubuntu and after selecting the option from the menu to "Install Ubuntu" it hangs on a blank screen.
I have seen other posts related to this and tried their solutions, however I have had no success. I was able to install 15.04 however the resolution is terrible and want to upgrade so that it would possibly fix this problem. I ran
inxi -Fxxxz in case you needed more info about my computer:
System: Kernel: 3.19.0-82-generic x86_64 (64 bit gcc: 4.9.2)
Desktop: Unity 7.3.2 (Gtk 3.14.13-0ubuntu1) dm: lightdm
Distro: Ubuntu 15.04 vivid
Machine: System: HP product: HP Pavilion Notebook Chassis: type: 10
Mobo: HP model: 80AF v: 81.32
Bios: American Megatrends v: F.41 date: 09/19/2016
CPU: Quad core AMD A10-8700P Radeon R6 10 Compute Cores 4C+6G (-MCP-) cache: 4096 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm) bmips: 14373
clock speeds: min/max: 1300/1800 MHz 1: 1600 MHz 2: 1300 MHz
3: 1600 MHz 4: 1300 MHz
Graphics: Card: Advanced Micro Devices [AMD/ATI] Device 9874
bus-ID: 00:01.0 chip-ID: 1002:9874
Display Server: X.Org 1.17.1 drivers: fbdev,ati (unloaded: vesa,radeon)
Resolution: 800x600@75.0hz
GLX Renderer: Gallium 0.4 on llvmpipe (LLVM 3.6, 128 bits)
GLX Version: 3.0 Mesa 10.5.9 Direct Rendering: Yes
Audio: Card-1 Advanced Micro Devices [AMD] Device 157a
driver: snd_hda_intel bus-ID: 00:09.2 chip-ID: 1022:157a
Card-2 Advanced Micro Devices [AMD/ATI] Kabini HDMI/DP Audio
driver: snd_hda_intel bus-ID: 00:01.1 chip-ID: 1002:9840
Sound: Advanced Linux Sound Architecture v: k3.19.0-82-generic
Network: Card-1: Realtek RTL8101E/RTL8102E PCI Express Fast Ethernet controller
driver: r8169 v: 2.3LK-NAPI port: e000
bus-ID: 02:00.0 chip-ID: 10ec:8136
IF: eth0 state: up speed: 100 Mbps duplex: full mac: <filter>
Card-2: Broadcom BCM43142 802.11b/g/n
driver: bcma-pci-bridge bus-ID: 03:00.0 chip-ID: 14e4:4365
IF: N/A state: N/A mac: N/A
Drives: HDD Total Size: 1008.3GB (0.5% used)
ID-1: /dev/sda model: TOSHIBA_MQ01ABD1 size: 1000.2GB serial: 1685P1RBT temp: 36C
ID-2: USB /dev/sdb model: USB_DISK size: 8.1GB serial: DISK-0:0 temp: 0C
Partition: ID-1: / size: 242G used: 4.6G (2%) fs: ext4 dev: /dev/sda5
RAID: System: supported: N/A
No RAID devices: /proc/mdstat, md_mod kernel module present
Unused Devices: none
Sensors: System Temperatures: cpu: 48.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 196 Uptime: 6 min Memory: 625.3/7364.8MB
Init: systemd v: 219 runlevel: 5 default: 2 Gcc sys: 4.9.2
Client: Shell (bash 4.3.301 running in gnome-terminal-)
inxi: 2.2.16
