I usually use eclipse , but I said "lets do some fantasy" to myself and things happened. I tried to use terminal command javac at first. I got
 The program 'javac' can be found in the following packages:
* default-jdk
* ecj
* gcj-5-jdk
* openjdk-8-jdk-headless
* gcj-4.8-jdk
* gcj-4.9-jdk
* openjdk-9-jdk-headless
Try: sudo apt install (selected package)
I already installed jre8 and jdk8 manually from oracle's website (standard edition) and I'm making programs with eclipse already. Then I typed java -version and the answer was
openjdk version "9-internal"
OpenJDK Runtime Environment (build 9-internal+0-2016-04-14-195246.buildd.src)
OpenJDK 64-Bit Server VM (build 9-internal+0-2016-04-14-195246.buildd.src, mixed mode)
which is not what i installed manually. Then I used locate -br ^javac$ and got two locations (not a surprise). So:
  1. I can use javac only with the path to where I installed jdk manually, but I wanna use commands without path, just directly . Is that possible (if yes then how ?
  2. It seems like I have two java versions. Does that cause any problem? If it does, tell me how to fix please (I prefer eliminating openjdk9)
Zanna
  • 72,312
buraky
  • 121
You can choose your default java by running update-alternatives:
$ sudo update-alternatives --config java
There are 5 choices for the alternative java (providing /usr/bin/java).
Selection    Path                                            Priority   Status
  0            /usr/lib/jvm/java-9-oracle/bin/java              1091      auto mode
  1            /usr/lib/jvm/java-8-openjdk-amd64/jre/bin/java   1081      manual mode
  2            /usr/lib/jvm/java-8-oracle/jre/bin/java          1081      manual mode
* 3            /usr/lib/jvm/java-9-oracle/bin/java              1091      manual mode
  4            /usr/lib/jvm/jdk1.8.0_91                         100       manual mode
  5            /usr/lib/jvm/jdk1.8.0_91/bin/java                100       manual mode
Press <enter> to keep the current choice[*], or type selection number:
Now to change your version simple type a number and hit Enter or to keep the default, just hit Enter. Do the same for the compiler :
sudo update-alternatives --config javac
And make your choice. Now one can also use a better command update-java-alternatives as recommended by Chai.
Now assuming you have these java packages installed:
java-9-oracle
jdk1.8.0_91
And I want the java-9-oracle version, then I will simply run:
sudo update-java-alternatives -s <java_name>
sudo update-java-alternatives -s java-9-oracle
This would create all the needed links to my desired java version.
Now in the light that you placed java in a different location we will use update-alternatives --install to let it know where our java is.
sudo update-alternatives --install /usr/bin/java java /usr/share/java/jdk1.8.0_121/bin/java 1
And for the compiler javac the same
sudo update-alternatives --install /usr/bin/javac javac /usr/share/java/jdk1.8.0_121/bin/javac 1
Source: man update-java-alternatives
George Udosen
  • 37,534
