I would like to form persistent group so that after a disconnection, when previously disconnected device sends connection invitation GO doesn't need to accept the invitation. Here's an example, which will explain my problem better: I have nodes sta-1, sta-2, and sta-3. sta-1 creates group, then sta-2 and sta-3 send connection invitation to sta-1 with the line
p2p_connect <sta-1 MAC address> pbc persistent join
Then, sta-1 accepts the connection invitation using
wps_pbc any
Group formation is complete now. Then, I disconnect sta-1 tearing the group down. After this point, when either sta-1 or sta-2 (or both) send connection invitation to sta-1 with the same command above, I expect connection to happen automatically without the need of any confirmation, because I had created a consisted group. However, connection doesn't take place if I do not use wps_pbc any again.
At this point, my question is: how can I realize persistent connection without need of confirmation for connection invitation?
Eric
  • 43
In readme of the wpa_supplicant u can get something like
set persistent_reconnect <0/1>
Disable/enabled persistent reconnect for reinvocation of persistent
groups. If enabled, invitations to reinvoke a persistent group will be
accepted without separate authorization (e.g., user interaction).
vishal
  • 95
