How to allow an account to login at the greeter without typing the password in Lubuntu 16.10?
I think I remember that worked in Ubuntu but I have not found a way to make that work in Lubuntu
GUI Try 1
I tried the gui way: "user & groups" -> change password -> [check] "don't ask password on login". And then reboot computer.
That doesn't work. The lightdm gtk greeter surely doesn't ask for a password for the user (let's say it is called user2), but then after I click ok, then the hard disk run for a while and then I go back to the login in screen again.
Original Config
/etc/lightdm/lightdm.conf:
[SeatDefaults]
# Check https://bugs.launchpad.net/lightdm/+bug/854261 before setting a timeout
user-session=Lubuntu
greeter-session=lightdm-gtk-greeter
allow-guest=false
Config File Try 1
I undo the gui try. Added the following lines to /etc/lightdm/lightdm.conf.d/20-lubuntu.conf, which was empty before I added these lines.
[SeatDefaults]
autologin-user=user2
autologin-user-timeout=delay
I reboot the computer, and find that I still need to password to login at lightgreeter.
Config File Try 2
I undo other changes to the configuration files. Undo the gui try. I followed How to make Lubuntu login automatically?
Add the following lines to /etc/lightdm/lightdm.conf
[Seat:*]
pam-service=lightdm
pam-autologin-service=lightdm-autologin
autologin-user-timeout=0
After that I reboot the computer. Still need password to login.
Config File Try 3
add the following lines under the existing section [SeatDefaults] to /etc/lightdm/lightdm.conf,
After that , I reboot the computer. Still need password for login.
Config File Try 4
I undo config file try 3, and didn't use the gui try. I back up /etc/lightdm/lightdm.conf to /etc/lightdm/lightdm.conf.orig and then replace /etc/lightdm/lightdm.conf with Organic Marble's config file:
[Seat:*]
autologin-guest = false
autologin-user = user2
autologin-user-timeout = 0
[SeatDefaults]
allow-guest = false
After that, I reboot the computer. Still need password to log in as user2 at the greeter.
New Account (Workaround 1)
I create a new account called user3. When I create it I choose not to encrypt homefolder, I also choose to login automatically before I actually log into the account. After that, automatic login on the account seems to work, so far.
I can try to replicate everything I did for user2 at the user3 account. But ideally, I should just click the checkbox for user2, and make autologin work for the existing account...
Summary
I don't know why only the gui way changes the behavior of the greeter (it makes the greeter doesn't ask for a password, but it also doesn't let me login. I certain hear some hard-disk noise for a few seconds though.).
Here is one more to try. This is from a 16.04 system, not 16.10 but is proven to work there. This is the complete contents of my lightdm.conf file.
[Seat:*]
[SeatDefaults]
allow-guest = false
Here is a complete lightdm.conf from a different 16.04 system, which also works.
[SeatDefaults]
user-session = Lubuntu
greeter-session = lightdm-gtk-greeter
allow-guest = false
If I understand correctly, GUI Try 1 only failed because after the screen slept you needed to log back in. That can be fixed by going to Settings -> Brightness and Lock -> uncheck require password in Ubuntu system settings.
brndn2k
  • 164
  • 16
