Here is my problem: Lately I had a problem with my BQ Aquaris E4.5 Ubuntu Edition that had me reinitialize it to factory settings. Now it works aproperly but I can't use adb.
I have Ubuntu 16.04 LTS in the computer, I have done the latest OTA updates on my phone, developer mode is enabled and code protected, I have installed all phablet-tools and parametered ~/.android/adb_usb.ini and /etc/udev/rules.d/51-android.rules according to what I found on the internet (I can post it if you want) but still when I run adb kill-server && adb devices, I keep getting:
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
List of devices attached
JU025119    unauthorized
Can anybody help?
bsl
  • 13
When doing a factory reset adb will be turn off by default. You can change this by using the --developer-mode argument with the ubuntu-device-flash command. You will also need to provide a password and wipe the device like so:
ubuntu-device-flash --channel ubuntu-touch/stable/bq-aquaris.en --wipe --developer-mode --password=password123
If you have already factory reset without enabling developer mode you can enable it from the settings app if you go to "About" > "Developer mode" and tap the "Developer Mode" switch. You will need to add a password or pin before you can enable developer mode.
