i have an XTECH XTM-510 mouse
my problem is that the mouse wheel acts not only jumpy but wonky, like sometimes it wont scroll, and when i scroll down it would scroll up or scroll down and on the last scroll it would instead scroll up, it would also act this wonky when i scroll up
it happens on every app, window, whatever, even on the shell vol and bright controls.
this problem also happened on a windows 7 desktop but it disappeared when i installed Microsoft Intellipoint Drive (a driver setup for microsoft crappy mouses), all i did after installing that driver was select the mouse most similar to mine and set scroll acceleration at 2, the problem was non-existent on both windows 8 and 10
i've already read the other questions that are similar to mine, but none of them had an answer to my problem, or at least not one that i could understand or implement
for example: Mouse wheel jumpy on scrolling the last answer, last paragraph captioned solution seems like something that can work but i have no least idea on how to implement such solution
so now having no idea how to fix this problem i decided to post my question here
I had this same problem, and searched for an answer -- then I tried a different mouse, and the problem went away. Turns out the scroll wheel on my mouse was just dirty inside, and when I cleaned it (I blew it off with a can of compressed air), it worked fine. YMMV of course.
See also Mouse wheel doesn't scroll up
If it is a wireless mouse try connecting the dongle with a USB extension cord, locate the dongle where the computer case will not block the signal, worked for me on 2 computers.
B. Fife
  • 49
