I usually use PlayOnLinux to manage my WINE versions via the interface, however, I would like to change my "system" WINE version (the version that loads when I double-click a file) so that I can just double-click on files to run them in the latest version of WINE even if they're the same "wineprefix". I have read the answer to this question but the versions in that repository only go up to version 1.8.
I would like the ability to make my system version of WINE 2.3 and keep it updated to the latest version automatically, so I don't want to manually compile or download packages all the time.
Also, if possible, I would like my system version to be a 32-bit one, and to instead use PlayOnLinux if I need a 64-bit wineprefix.
I am running Xubuntu 16.04 LTS 64-bit.
EDIT: I thought I'd include a list of commands to wipe & update Wine (EDIT 2: updated for 18.04, EDIT 3: Updated again for Ubuntu 18.04 in 2019):
# Remove old Wine
rm -Rf ~/.wine
sudo apt purge -y wine*
# Add key and repo
sudo dpkg --add-architecture i386
wget -nc https://dl.winehq.org/wine-builds/winehq.key
sudo apt-key add winehq.key
sudo add-apt-repository -y 'deb https://dl.winehq.org/wine-builds/ubuntu/ bionic main'
sudo add-apt-repository -y 'ppa:cybermax-dexter/sdl2-backport'
rm -f winehq.key
# Install
sudo apt update
sudo apt full-upgrade -y
sudo apt install -y winehq-devel playonlinux
# This is optional, but some programs need it.
sudo sed -i -e 's/scope = 1/scope = 0/g' /etc/sysctl.d/10-ptrace.conf
# Did it work?
wine --version
Thanks to everyone who answered. This doesn't include changing Winearch, see below for that.
Aaron Franke
  • 1,136
Install latest WINE version for Ubuntu
sudo add-apt-repository ppa:wine/wine-builds
sudo apt-get update && sudo apt-get install winehq-devel
Run 32-bit WINE for default (rm old ~/.wine folder first)
WINEARCH=win32 WINEPREFIX=~/.wine winecfg
You can change different WINEPREFIX folder for 32-bit and 64-bit WINE environment
WINEARCH=win32 WINEPREFIX=~/win32 winecfg
Or
WINEARCH=win64 WINEPREFIX=~/win64 winecfg
tagplus5
  • 248
So you know that Wine has moved to the new repository.
Now let me share the commands here:
wget https://dl.winehq.org/wine-builds/Release.key
sudo apt-key add Release.key
sudo apt-add-repository 'https://dl.winehq.org/wine-builds/ubuntu/'
See: Packaging related changes.
kenorb
  • 10,944
Yahya
  • 183
