Hello again Ubuntu users
I'm trying some new things with mkdir and I can't quite get the hang of things
I want to learn how to make a directory inside of a specified path, then a touch.txt text document with words inside or a story
So far I've got
 mkdir ~/Desktop/new_file touch ~/Desktop/new_file/adas.txt
But that doesn't work, and not sure how to get words in it all from one command line
Seth
  • 59,332
This could be done this way:
mkdir ~/Desktop/new_file && touch ~/Desktop/new_file/adas.txt && echo "Hello World" > ~/Desktop/new_file/adas.txt
Information:
  1. && This ensures that the command preceding it executes correctly before the next command, hence if the preceding command fails the next won't execute.
  2. > Directs the output of the echo command into the adas.txt file.
George Udosen
  • 37,534
You might consider using mkdir --parents (or mkdir -p for short) to avoid an error if the directory already exists (you can also create nested directories this way, e.g mkdir -p dir1/dir2/dir3 will create the requested directories and not throw an error if they already exist).
You may also want to consider omitting the touch command entirely as > will create the file for you if it doesn't already exist (FYI: >> will append to the end of an existing file, wheras > will overwrite an existing file.
So,
mkdir -p ~/Desktop/new_file && echo "Hello World" > ~/Desktop/new_file/adas.txt
Should do what you want, then you could later do things like:
echo "More text to add" >> ~/Desktop/new_file
More info can be found in the bash manpage (man bash under SHELL GRAMMAR (particularly the Lists section.
Good Luck
