I just installed Ubuntu. I wanted to load a software to allow me to graphically manage media.
  1. I got a Terminal.
  2. I entered the following: sudo apt-get install synaptic
  3. The screen prompt demanded a password.
  4. I entered my password (not the passphrase) result was
    • the system did not seem to be allowing keyboard input At least there was no movement of the cursor and
    • the system did not recognize my password no matter how many times I entered it.
What am I doing wrong?
Also I am getting the following when I use the command line
System-Product-Name-Invalid-entry-length-16-Fixed-up-to-11:~$
What's that?
I tried it again using UXterminal from the Dash this time it recognized my password and gave me a Y/n option and I chose Y
Zanna
  • 72,312
To reset admin password, Boot up the machine, and after the BIOS screen, hold down the left Shift key. You will then be prompted by a menu -Enter the recovery mode. -Using the arrow keys scroll down to root and then hit Enter -At this stage you should have a read-only filesystem. You have to remount it with write permissions:
mount -o rw,remount /
-Now we can set the user's password with the passwd command.
Sazzy
  • 67
The message that you receive in your terminal,
It means that your hostname (name of the computer) it's too long.
To change the computer name in Ubuntu, you have to edit two text files, namely /etc/hostname and /etc/hosts.
After editing the files save them and restart your computer.
  • You can also change the computer name by typing this command in terminal:
(change "pc-name" with the name you want for your PC):
hostnamectl set-hostname pc-name
and then reboot.
