13
Ive just installed ubuntu 16.04.2 32 bit on a digital ocean server.
Digital ocean has tweaked the ubuntu install a bit, for example they have installed full vim as part of the block image they use in their VPS's. I now want to use this - pre-installed - vim as my default editor. so I run
sudo update-alternatives --config editor
which gives this menu
$ sudo update-alternatives --config editor
There are 4 choices for the alternative editor (providing /usr/bin/editor).
  Selection    Path                Priority   Status
* 0            /bin/nano            40        auto mode
  1            /bin/ed             -100       manual mode
  2            /bin/nano            40        manual mode
  3            /usr/bin/vim.basic   30        manual mode
  4            /usr/bin/vim.tiny    10        manual mode
Press <enter> to keep the current choice[*], or type selection number:
note: vim is not there as an option
Im thinking digital ocean has not added the vim install to the update-alternatives system?
What is the recommended way to get the /user/bin/vim program added to this menu?
I guess I could overwrite the /usr/bin/editor symlink that the alternatives system adds or maybe add a symlink in /etc/alternatives pointing to /usr/bin/vim ? but I would like to try the "official" way before I do my "hack" on top of the digital ocean hack.
First set your editor to the right path:
sudo update-alternatives --install /usr/bin/editor editor /usr/local/bin/vim 1 && \
sudo update-alternatives --set editor /usr/local/bin/vim
Then aliases:
sudo update-alternatives --install /usr/bin/vi vi /usr/local/bin/vim 1 && \
sudo update-alternatives --set vi /usr/local/bin/vim
Don't forget the 1 near the end of the first line of both code blocks above.
10
This is not modified, but the standard Ubuntu behaviour up to Zesty. If you do a ls -l on vim (/usr/bin/vim), you see that it is a link to /etc/alternatives/vim, which in turn links to /usr/bin/vim.basic.
Execution of vim --version or vim.basic --version also reveals that they are in fact the same full, "giant" vim version 8.0 without GUI.
To answer your question: Menu choice of vim.basic gives you the desired full vim version. It is just that the name is misleading.
emk2203
  • 4,393
  • 26
  • 52
You can add any new editor and set it as default by using a single command. In this example you would be adding micro editor, located in /usr/bin/micro as an update alternative editor with a priority of 100. The command is:
sudo update-alternatives --install /usr/bin/editor editor /usr/bin/micro 100
The system will use the editor with the highest priority by default if there isn't any previous selection. So, with this single command, you can add a new editor, and use it as the default editor. All you need is that the priority is larger than any of the previous you have in your update-alternatives list.
Pablo Bianchi
  • 17,371
Oscar
  • 181
