Linux is compiled from open-source and thousands of developers would spot any malicious source code. However many Linux users dual boot Windows and malware / spyware / "spook"ware (CIA) software could hack the compiled binaries of Linux after a clean version was installed.
The solution I think is to run a hash total on Linux Kernel binaries immediately after an update is installed, ie on 4.4.0-63-generic.
The question is which files need to be included? ie /boot/4.4.0-63-generic or more than that?
After the hash total is generated a cron job can be run monthly, weekly or daily to regenerate the hash total and compare it to the original version to ensure it hasn't changed. If the hash totals don't match an infection has occurred and a clean kernel needs to be reinstalled.
Edit 1 The answers so far are more like comments. Those answers and the comments below seem to say "The CIA is too smart and too rich to protect yourself so don't bother trying". If I read that right then all the answers might as well be written by one the CIA, NSA, MI6 or Mossad paid trolls or someone on spook payroll. An analogy would be "Your neighbourhood criminals are too smart and sophisticated. They watch your house and learn your habits. There is no point locking your doors or installing an alarm system."
Someone else says once you reboot with Windows the password you used to encrypt your hash totals can be read by spyware. I doubt that because Windows RAM footprint is larger than Linux's RAM footprint and loading windows would wipe out any valuable searchable RAM Linux may have left behind. Besides a simple 10 second power off would erase all RAM.
At the opposite end of the spectrum someone suggested "Don't use Windows". Um... no I won't hide in fear and avoid the platforms I need to use when I need to use them. It's a super fast laptop with a hybrid nVidia graphics and when it's time for Windows gaming it will be used as such.
  1. This is more of a how would you do it, but with kernel update you would obviously need to rerun the hash, to create a new one. But what if you forgot to rerun it, what would happen then?
With a kernel update an entirely new kernel is installed to /boot. If you forget to run the job to create new hash totals then the cron job that compares totals will give you an error the same way as if someone had modified kernel binaries behind your back.
The actual design of scripts and encryption of hash totals comes later. We are putting the cart in front of the horse. The fist step is to identify what needs to be protected. It's NAA (Not An Answer) to post questions on "how would you do it?" embedded in an answer.
Partially answering my question in addition to running hash totals on Kernel images, selected drivers should be included. Specifically I'm thinking of the one where they can turn off power to webcam led's giving the illusion they are turned off and then activating the camera. Something similar with mic's perhaps?
Removing all speculation on whether you should or should not monitor unauthorized modifications to your kernel space--what binaries should be protected from external tampering?
The only way I see to avoid this scenario is to avoid dual-boot: get rid of Windows. Of course, if you think the CIA can't install malware that will hide in a desktop/laptop Linux system, you're not paranoid enough...
Zeiss Ikon
  • 5,248
Learn how make grub work for you, and set it up in order to boot linux distributions that are kept within .iso archives ever time that you boot. Keep your Windoze machine at home and only allow it to talk via direct hard-linked connection, to the linux box that you allow to talk to the internet on each boot, and configure all internet activity remotely, through the linux system that gets initialized each time it gets booted. For those that are hyper-paranoid, make bootable flash drives, that you keep in you pocket, and turn off boot-from-USB, whenever you leave the house, on the linux device. All involved boxes would be password protected, at the BIOS level, of course! ;^)
Here is a sampling of other kernel binaries to protect besides those in /boot:
$ ls /lib/modules/4.9.13-040913-generic/
build          modules.alias.bin    modules.dep.bin  modules.symbols
initrd         modules.builtin      modules.devname  modules.symbols.bin
kernel         modules.builtin.bin  modules.order    updates
modules.alias  modules.dep          modules.softdep  vdso
rick@dell:~$ ls /lib/modules/4.9.13-040913-generic/kernel
arch  crypto  drivers  fs  kernel  lib  mm  net  sound  virt
rick@dell:~$ ls /lib/modules/4.9.13-040913-generic/kernel/drivers
acpi        dca       hwmon       mcb       nvme      rapidio      uio
ata         dma       hwtracing   md        nvmem     regulator    usb
atm         edac      i2c         media     parport   reset        uwb
auxdisplay  extcon    iio         memstick  pci       rtc          vfio
base        firewire  infiniband  message   pcmcia    scsi         vhost
bcma        firmware  input       mfd       phy       spi          video
block       fmc       iommu       misc      pinctrl   spmi         virtio
bluetooth   fpga      ipack       mmc       platform  ssb          vme
char        gpio      isdn        mtd       power     staging      w1
clk         gpu       leds        net       powercap  target       watchdog
cpufreq     hid       lightnvm    nfc       pps       thermal      xen
crypto      hsi       macintosh   ntb       ptp       thunderbolt
dax         hv        mailbox     nvdimm    pwm       tty
rick@dell:~$ ls /lib/modules/4.9.13-040913-generic/kernel/drivers/net/ethernet/realtek/
8139cp.ko  8139too.ko  atp.ko  r8169.ko
rick@dell:~$
A recursive algorithm is needed to take md5sum snapshot (or whichever security hashsum you prefer) of all sub-directories and files in the directory /lib/modules/kernel_version/*
There are probably other binaries but I wanted to post an answer of what has been discovered so far.
