I am using Ubuntu 14.04LTS on a thinkpad with an intel integrate card and a nvidia card.
Everything is fine with nvidia-304 or nvidia-340. However, every time I install newer nvidia driver such as nvidia-352, nvidia-361 or nvidia-367, I would be greeted with a black screen after reboot. I can hear the greeting sound of ubuntu, but cannot see anything. Then I have to remove the nvidia drivers.
All the commands are:
sudo apt-get install nvidia-version
sudo apt-get remove nvidia* --purge
Why is this happening? Are there any methods to prevent this problem? Any help would be appreciated!!
Update:
I installed nvidia-375 but was still greeted by a black screen.Then I installed nvidia-prime and insert the command 'prime-select intel'. Then the black screen has gone. But it seems that it simply avoids using the nvidia driver and card instead of solving the real problem. Even if it works, as I prefer bumblebee, I think installing nvidia-prime is not the best solution.
P.S.
I have found some answers about how to fix the black screen problem, but none of them can help me install newer version of nvidia driver.
Some other information:
lspci |grep 3D
01:00.0 3D controller: NVIDIA Corporation GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M]
I had nvidia 378 when I tried to install CUDA 8.0 and during the install process my drivers got downgraded to 375.
This is the process I followed to install them (taken from my notes so I can re-install faster if needed). As mentioned by Mark Kirby do not use xorg ppa.
### Add nvidia drivers
sudo add-apt-repository ppa:graphics-drivers/ppa
# More Info on https://launchpad.net/~graphics-drivers/+archive/ubuntu/ppa
sudo apt update
sudo apt-get install nvidia-378
You will have to research the dependencies between your graphic card, CUDA versions and the software for which you need CUDA. Hopefully you 'll be able to find a sweet spot where all can live together.
P.S. My GPU is nvidia 1050Ti so nvidia-378 was fine (but CUDA still downgraded it). For your graphic card 375/378 may not work (as you already experienced issues).
edit: You didn't mention if you tried nvidia-375 in your post. If not give it a try to see if it works.
Karsus
  • 961
