I'm trying to increase the 'open files' to both a regular user and to root user. Been applying different procedures from different sources without success. I'm using Ubuntu 16.10 with Linux 4.8.0-41-generic, and these are the changes I've made so far:
$ grep nofile /etc/security/limits.conf
#        - nofile - max number of open files
root     - nofile       80000
*        - nofile       80000
$ grep pam_limits /etc/pam.d/*
/etc/pam.d/common-session:session required  pam_limits.so
/etc/pam.d/common-session-noninteractive:session    required    pam_limits.so
/etc/pam.d/login:session    required   pam_limits.so
$ grep file-max /etc/sysctl.conf
fs.file-max=80000
$ cat /proc/sys/fs/file-max
80000
I've then rebooted. After reboot when I check with 'ulimit':
$ ulimit -Sn
1024
$ ulimit -Hn
4096
wjandrea
  • 14,504
alex
  • 51
Does Ubuntu v16.10 use systemd? Then you may be running into the problem where graphical logins are started by systemd which doesn't use /etc/security/limits*. See this answer instead:
https://superuser.com/a/1322187/116705
