Trying to access windows share folder from Ubuntu 16.04 desktop and following dialog appears.
smb Unhandled error message: Failed to retrieve share list from server: No such file or directory
I find out my default Ubuntu don't have samba installed when i try to install
sudo apt install samba
It failes with following trace
Reading package lists... Done
Building dependency tree
samba : Depends: python-samba but it is not going to be installed
Depends: samba-common-bin (= 2:4.3.8+dfsg-0ubuntu1) but it is not going to be installed
Depends: libwbclient0 (= 2:4.3.8+dfsg-0ubuntu1) but 2:4.3.11+dfsg-0ubuntu0.16.04.3 is to be installed
Depends: samba-libs (= 2:4.3.8+dfsg-0ubuntu1) but 2:4.3.11+dfsg-0ubuntu0.16.04.3 is to be installed
Recommends: attr
Recommends: samba-dsdb-modules but it is not going to be installed
Recommends: samba-vfs-modules but it is not going to be installed
