I have only been using Linux for a few months and am not too familiar with different errors. I have never seen this one before and have no idea how to make sense of it. I am trying to install valgrind to test a couple programs for memory leaks. I have tried installing it two different ways and get a similar but different error both ways.
When I try installing it with sudo apt install valgrind this is the error I get:
(Reading package lists... Done
Building dependency tree
Suggested packages:
  valgrind-dbg kcachegrind alleyoop valkyrie
The following NEW packages will be installed:
  valgrind
0 upgraded, 1 newly installed, 0 to remove and 225 not upgraded.
1 not fully installed or removed.
Need to get 0 B/11.0 MB of archives.
After this operation, 66.8 MB of additional disk space will be used.
Setting up util-linux (2.27.1-6ubuntu3.2) ...
insserv: warning: script 'K01vpnagentd_init' missing LSB tags and overrides
insserv: warning: script 'vpnagentd_init' missing LSB tags and overrides
insserv: There is a loop between service plymouth and procps if started
insserv:  loop involving service procps at depth 2
insserv:  loop involving service udev at depth 1
insserv: Starting vpnagentd_init depends on plymouth and therefore on system facility `$all' which can not be true!
insserv: Max recursions depth 99 reached
insserv: There is a loop at service plymouth if started
insserv: There is a loop between service vpnagentd_init and hwclock if started
insserv:  loop involving service hwclock at depth 1
insserv: There is a loop at service vpnagentd_init if started
insserv:  loop involving service networking at depth 4
insserv: There is a loop between service plymouth and urandom if started
insserv:  loop involving service urandom at depth 4
insserv:  loop involving service mountdevsubfs at depth 2
insserv: There is a loop between service vpnagentd_init and dns-clean if started
insserv:  loop involving service dns-clean at depth 1
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg: error processing package util-linux (--configure):
 subprocess installed post-installation script returned error exit status 1
 util-linux
I also tried installing with sudo apt-get install valgrind, and I get this error:
Suggested packages:
  valgrind
insserv: Starting vpnagentd_init depends on ondemand and therefore on system facility `$all' which can not be true!
insserv: There is a loop between service vpnagentd_init and ondemand if started
insserv:  loop involving service ondemand at depth 7
insserv:  loop involving service vpnagentd_init at depth 1
 util-linux
Any help would be very much appreciated. Cheers!
ash
  • 2,207
Alex
