I'm quite new at this because I've been using windows and now I'm stuck not knowing what to do. I created a bootable USB stick with Rufus, changed the boot options and started to boot Ubuntu. It shows the grub menu and the first 2 choices are install or try without installing. When I select either on of those 2, it starts booting but then hangs in the loading screen. I pressed F2 and I get the error:
can't request region for resource
I have tried every possible combination of BIOS settings, Rufus settings and some of the solutions that I found online but nothing works. I even formatted Windows 10 and still nothing. All drivers are up to date. I just run out of ideas, need help.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
ChrisCM
  • 29
The solution was a mixture of both of those threads. By getting started Ubuntu with the nomodeset I was able to install both Ubuntu and the drivers needed (I have 2 graphics cards in my laptop and apparently that causes the problem) and now everything runs smoothly.
abu_bua
  • 11,313
ChrisCM
  • 29
