Used to work just fine. But I set something else on channel 2 and proceeded to pair it with the PC on channel 1. Well it seems to not be possible anymore. I followed the tutorial (power on mouse, select chan, press connect, plug-in receiver) lots of times. Can't get it to connect. It just keeps rapidly blinking.
I even tried shutting off all bluetooth devices in the house just in case they are confusing it. The ubuntu solaar software that mimics the logitech software seems to be discontinued.
So, what else to try here?
Please note that it used to work, I just can't pair it again.
As mentioned in the comment, try out Solaar:
sudo apt-get update && sudo apt-get install solaar
Once you run it, you can manage the pairing of your MX Master.
I had a similar problem; I think I overwrote the channel that was paired with the receiver. I cleared up the pairing with Solaar and then paired the mouse again: works like a charm.
