lsmod | grep acc
hp_accel 28672 0
lis3lv02d 20480 1 hp_accel
How do I get output out of this thing?
and there's xrandr --output eDP1 --rotate normal or inverted or left or right. I want to use the sensor output to trigger those command & do screen rotation.
edit:
After upgrading kernel now I get this when I run lsmod | grep acc
hid_sensor_accel_3d 16384 1
hid_sensor_trigger 16384 15 hid_sensor_incl_3d,hid_sensor_accel_3d,hid_sensor_magn_3d,hid_sensor_gyro_3d,hid_sensor_rotation
industrialio_triggered_buffer 16384 5 hid_sensor_incl_3d,hid_sensor_accel_3d,hid_sensor_magn_3d,hid_sensor_gyro_3d,hid_sensor_rotation
hid_sensor_iio_common 16384 6 hid_sensor_incl_3d,hid_sensor_accel_3d,hid_sensor_trigger,hid_sensor_magn_3d,hid_sensor_gyro_3d,hid_sensor_rotation
industrialio 69632 10 hid_sensor_incl_3d,hid_sensor_accel_3d,acpi_als,hid_sensor_trigger,hid_sensor_magn_3d,hid_sensor_gyro_3d,hid_sensor_rotation,industrialio_triggered_buffer,kfifo_buf
hp_accel 28672 0
hid_sensor_hub 20480 8 hid_sensor_incl_3d,hid_sensor_accel_3d,hid_sensor_iio_common,hid_sensor_trigger,hid_sensor_magn_3d,hid_sensor_gyro_3d,hid_sensor_rotation,hid_sensor_custom
edit2:
iio-sensor-proxy isn't running. Trying sudo iio-sensor-proxy gives
** (process:2721): WARNING **: Failed to read float from /sys/devices/pci0000:00/0000:00:13.0/{33AECD58-B679-4E54-9BD9-A04D34F0C226}/001F:8086:22D8.0001/HID-SENSOR-200073.8.auto/iio:device6/in_scale
** (process:2721): WARNING **: Problem reading scan element information: /sys/devices/pci0000:00/0000:00:13.0/{33AECD58-B679-4E54-9BD9-A04D34F0C226}/001F:8086:22D8.0001/HID-SENSOR-200073.8.auto/iio:device6
and the terminal remains blank till I ^C.
Trying sudo systemctl start iio-sensor-proxy outputs nothing till it timeouts
Job for iio-sensor-proxy.service failed because a timeout was exceeded. See "systemctl status iio-sensor-proxy.service" and "journalctl -xe" for details.
● iio-sensor-proxy.service - IIO Sensor Proxy service
Loaded: loaded (/lib/systemd/system/iio-sensor-proxy.service; static; vendor preset: enabled)
Active: failed (Result: timeout) since Wed 2017-05-24 16:12:03 EET; 5min ago
Process: 3335 ExecStart=/usr/sbin/iio-sensor-proxy (code=killed, signal=TERM)
Main PID: 3335 (code=killed, signal=TERM)
May 24 16:10:33 gas systemd[1]: Starting IIO Sensor Proxy service...
May 24 16:12:03 gas systemd[1]: iio-sensor-proxy.service: Start operation timed out. Terminating.
May 24 16:12:03 gas systemd[1]: Failed to start IIO Sensor Proxy service.
May 24 16:12:03 gas systemd[1]: iio-sensor-proxy.service: Unit entered failed state.
May 24 16:12:03 gas systemd[1]: iio-sensor-proxy.service: Failed with result 'timeout'.
journalctl -xe (probably not very useful)
May 24 16:11:26 gas kernel: intel-vbtn INT33D6:01: unknown event index 0xcd
-- Subject: Unit iio-sensor-proxy.service has failed
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit iio-sensor-proxy.service has failed.
-- The result is failed.
May 24 16:12:03 gas sudo[3855]: pam_unix(sudo:session): session closed for user root
May 24 16:12:17 gas gnome-session[2010]: (nm-applet:2383): nm-applet-WARNING **: ModemManager is not avai
May 24 16:13:40 gas anacron[775]: Job `cron.daily' terminated
May 24 16:13:40 gas anacron[775]: Normal exit (1 job run)
May 24 16:13:50 gas org.gnome.zeitgeist.SimpleIndexer[1779]: ** (zeitgeist-fts:2514): WARNING **: Unable
May 24 16:14:14 gas gnome-session[2010]: (nm-applet:2383): nm-applet-WARNING **: ModemManager is not avai
May 24 16:14:43 gas org.gnome.zeitgeist.SimpleIndexer[1779]: ** (zeitgeist-fts:2514): WARNING **: Unable
May 24 16:15:01 gas CRON[4519]: pam_unix(cron:session): session opened for user root by (uid=0)
May 24 16:15:01 gas CRON[4520]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
May 24 16:15:01 gas CRON[4519]: pam_unix(cron:session): session closed for user root
May 24 16:15:02 gas org.gnome.zeitgeist.SimpleIndexer[1779]: ** (zeitgeist-fts:2514): WARNING **: Unable
May 24 16:15:15 gas org.gnome.zeitgeist.SimpleIndexer[1779]: ** (zeitgeist-fts:2514): WARNING **: Unable
May 24 16:15:26 gas org.gnome.zeitgeist.SimpleIndexer[1779]: ** (zeitgeist-fts:2514): WARNING **: Unable
May 24 16:15:49 gas /usr/lib/snapd/snapd[790]: snapmgr.go:450: No snaps to auto-refresh found
May 24 16:15:49 gas snapd[790]: 2017/05/24 16:15:49.321528 snapmgr.go:450: No snaps to auto-refresh found
May 24 16:15:51 gas org.gnome.zeitgeist.SimpleIndexer[1779]: ** (zeitgeist-fts:2514): WARNING **: Unable
May 24 16:16:13 gas gnome-session[2010]: (nm-applet:2383): nm-applet-WARNING **: ModemManager is not avai
May 24 16:16:58 gas org.gnome.zeitgeist.SimpleIndexer[1779]: ** (zeitgeist-fts:2514): WARNING **: Unable
May 24 16:17:01 gas CRON[4669]: pam_unix(cron:session): session opened for user root by (uid=0)
May 24 16:17:01 gas CRON[4670]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
May 24 16:17:01 gas CRON[4669]: pam_unix(cron:session): session closed for user root
May 24 16:17:46 gas org.gnome.zeitgeist.SimpleIndexer[1779]: ** (zeitgeist-fts:2514): WARNING **: Unable
May 24 16:18:00 gas org.gnome.zeitgeist.SimpleIndexer[1779]: ** (zeitgeist-fts:2514): WARNING **: Unable
...and yes my computer's name is gas X'D
I hope we can fix this sensor thing. I'm desperate to get it to work. It seems that we're getting there :)
