  • My PC has 8Gb DDR3 RAM.
  • I use Ubuntu 16.4.
I did not set swap memory due limitations of my HDD (which allows me only 4 active partitions).
Do I need swap? What difference does it make to my PC? What do I get from swap memory?
TRiG
  • 2,006
The purpose of SWAP is to extend your RAM using a special HDD partition or an file.
If the total of your memory usage won't reach to 8GB, the lack of SWAP partition won't affect you.
Note: If you would like to be able to hibernate your computer, then you should have a SWAP partition.
More info about SWAP can be found in What Is a Linux SWAP Partition, And What Does It Do?
Yaron
  • 13,453
