I have a question I have been researching for days on.  I have a MSI z97 gaming 5 board with 7 PCI slots.  All the slots work fine for GPU's as I have an identical board with 7 AMD GPU's running.  The other board I have 7 NVidia cards, GTX 1060 3GB.  With 6 cards this board runs fine, when I put in the 7th, I can see it when I do a lspci -v I can see all 7 NVidia cards.  Here is a difference between a working card and non working card.
Output from a working card:
02:00.0 VGA compatible controller: NVIDIA Corporation Device 1c02 (rev a1) (prog-if 00 [VGA controller])
       Subsystem: ASUSTeK Computer Inc. Device 85b1
       Flags: bus master, fast devsel, latency 0, IRQ 31
       Memory at f4000000 (32-bit, non-prefetchable) [size=16M]
       Memory at a0000000 (64-bit, prefetchable) [size=256M]
       Memory at b0000000 (64-bit, prefetchable) [size=32M]
       I/O ports at d000 [size=128]
       [virtual] Expansion ROM at f5000000 [disabled] [size=512K]
       Capabilities: [60] Power Management version 3
       Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
       Capabilities: [78] Express Legacy Endpoint, MSI 00
       Capabilities: [100] Virtual Channel
       Capabilities: [250] Latency Tolerance Reporting
       Capabilities: [128] Power Budgeting
       Capabilities: [420] Advanced Error Reporting
       Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024
       Capabilities: [900] #19
       Kernel driver in use: nvidia
       Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
Here is the output from the non-working 7th card:
03:00.0 VGA compatible controller: NVIDIA Corporation Device 1c02 (rev a1) (prog-if 00 [VGA controller])
       Subsystem: Device 196e:11d9
       Flags: bus master, fast devsel, latency 0, IRQ 32
       Memory at f2000000 (32-bit, non-prefetchable) [size=16M]
       Memory at 80000000 (64-bit, prefetchable) [size=256M]
       Memory at 90000000 (64-bit, prefetchable) [size=32M]
       I/O ports at c000 [size=128]
       [virtual] Expansion ROM at f3000000 [disabled] [size=512K]
[/root]:# lsdev Device DMA IRQ I/O Ports ------------------------------------------------ 0000:00:1f.3 f000-f01f 0000:01:00.0 e000-e07f 0000:02:00.0 d000-d07f 0000:03:00.0 c000-c07f 0000:05:00.0 b000-b07f 0000:06:00.0 a000-a07f 0000:07:00.0 9000-907f 0000:08:00.0 8000-807f 0000:09:00.0 7000-707f ACPI 1800-1803 1804-1805 1808-180b 1820-182f 1850-1850 acpi 9 cascade 4 dma 0080-008f dma1 0000-001f dma2 00c0-00df ehci_hcd:usb1 16 ehci_hcd:usb2 23 eth0 29 fpu 00f0-00ff i8042 1 12 iTCO_wdt.0.auto 1830-1833 1860-187f keyboard 0060-0060 0064-0064 mei_me 28 nvidia 30 31 32 33 34 35 PCI 0000-0cf7 0cf8-0cff 0d00-ffff 7000-7fff 8000-8fff 9000-9fff a000-afff b000-bfff c000-cfff d000-dfff e000-efff pic1 0020-0021 pic2 00a0-00a1 pnp 04d0-04d1 0800-087f 0a00-0a1f 0a20-0a2f 0a30-0a3f 1854-1857 PNP0C04:00 00f0-00f0 rtc0 8 0070-0077 serial 03f8-03ff timer 0 timer0 0040-0043 timer1 0050-0053 vga+ 03c0-03df xhci_hcd 27
The Subsystem: Device ID is what seems to jump out at me the most. So the board sees it but cannot give enough resources to use it?
Any chance someone knows what I can do to get this card working?
