I am accessing my server (Ubuntu based) from my local Ubuntu using terminal. I would like to open files on the server using my local application (for example, Sublime editor). Could anyone help me in this?
Asked
Active
Viewed 1,199 times
You can mount your Ubuntu server files to your local Ubuntu installation, and then edit those files with Sublime as if they were local.
The following assumes that you can SSH access to the Ubuntu server.
sudo apt-get install sshfs
This will install the sshfs package.
cd
mkdir ServerFiles/
sshfs myServerUsername@example.com:/home/myServerUsername/ ServerFiles/
Here you create an empty directory in your home folder and the sshfs command will connect it to your server's home directory.
You can now visit the ServerFiles/ directory with Sublime (or any other program) and you have direct access to your server files, locally!
To disconnect when you finish,
cd
fusermount -u MYSERVERMOUNT/
user4124
- 9,241
