I'm trying to delete a folder my music collection folder. With the command
ls -al /mnt/media/Music/
I can see the folder - only it has a ? at the end of the name, so it looks like this:
drwxrwxr-x 1 reuben reuben    0 Mar  3 15:24 Twin Shadow - Eclipse (2015) [FLAC]?
but when I try to delete it with this command:
rmdir /mnt/media/Music/Twin\ Shadow\ -\ Eclipse\ \(2015\)\ [FLAC]\?/
Then I get this:
rm: cannot remove '/mnt/media/Music/Twin Shadow - Eclipse (2015) [FLAC]?/': No such file or directory
I'm confused; what am I missing? I hope it's not something really obvious!
Zanna
  • 72,312
By far the easiest way to handle filenames like this in the terminal is to make use of the shell's tab completion feature: type enough of the name to be unambiguous e.g.
and then hit TAB
The second easiest way - at least if the name doesn't itself contain quotes - is to quote the whole thing e.g.
rmdir '/mnt/media/Twin Shadow - Eclipse (2015) [FLAC]?'
(double quotes should also work in this context).
If you really need to use backslash escapes, then both parentheses and square brackets are shell metacharacters and must also be escaped i.e.
rmdir /mnt/media/Music/Twin\ Shadow\ -\ Eclipse\ \(2015\)\ \[FLAC\]\?/
(the - doesn't need to be escaped - although it doesn't hurt to do so).
steeldriver
  • 142,475
