I have been trying set up my usb microphone to switch to default and loopback automatically with udev.
My current rules are:
ACTION=="add", ATTR{idVendor}=="046d", ATTR{idProduct}=="0a03", GROUP=="audio" RUN+="/usr/bin/micplug"
ACTION=="remove", ENV{ID_MODEL}=="Logitech_USB_Microphone", RUN+="/usr/bin/micunplug"
The micplug script is:
#!/bin/bash
echo "setting source mic" >> /home/wanderingconfused/test
pacmd set-default-source alsa_input.usb-Logitech_Logitech_USB_Microphone-00.analog-mono
echo "loopback mic" >> /home/wanderingconfused/test
pactl load-module module-loopback latency_msec=1 source=alsa_input.usb-Logitech_Logitech_USB_Microphone-00.analog-mono sink=alsa_output.pci-0000_00_14.2.analog-stereo
Which sets the mic as the default source and loopbacks it.
The micunplug script is:
#!/bin/bash
echo "turn off loopback" >> /home/wanderingconfused/test
pactl unload-module $(pactl list short modules | awk '$2 == "module-loopback" { print $1 }' - )
echo "setting source webcam" >> /home/wanderingconfused/test
pacmd set-default-source alsa_input.usb-046d_081b_4B042590-02.analog-mono
Which turns off the loopback and returns the default source to my webcam.
The scripts work exactly as intended on their own. However, when udev executes them my everything echoes to the test file, but pulseaudio ignores the commands.
I was thinking it had something to do with permissions, which is why I added GROUP. I have tried a couple groups and owners and tried MODE=="0660", but at this point I am stumped.
Edit 3/3/2017 So now my /usr/bin/pulse_events_wrapper is:
#!/bin/bash
# Get UID of user running pulseaudio (uses the first if more than one)
PUID=`ps -C pulseaudio -o ruid= | awk '{print $1}'`
if [ ! -z "$PUID" ]; then
  # environment variables to export
  export PULSE_RUNTIME_PATH="/var/run/user/$PUID/pulse"
  export HOME=`getent passwd $PUID | cut -d: -f6`
  if [ -x "$HOME/.pulse_events" ]; then
    # Pass single command line arg to user script
    nohup sudo -u "#$PUID" -E $HOME/.pulse_events $1 >/dev/null 2>&1 &
  fi
fi
and the home/.pulse_events script is
!/bin/bash
case $1 in
    micplug)
      pacmd set-default-source alsa_input.usb-Logitech_Logitech_USB_Microphone-00.analog-mono >>/home/wanderingconfused/test 2>&1
      pactl load-module module-loopback latency_msec=1 source=alsa_input.usb-Logitech_Logitech_USB_Microphone-00.analog-mono sink=alsa_output.pci-0000_00_14.2.analog-stereo$
    micunplug)
      pactl unload-module $(pactl list short modules | awk '$2 == "module-loopback" { print $1 }' - ) >>/home/wanderingconfused/test 2>&1
      pacmd set-default-source alsa_input.usb-046d_081b_4B042590-02.analog-mono >>/home/wanderingconfused/test 2>&1
esac
It works but I'd rather not be dumping all that into a file. I have tried removing the echos and routing everything to null, but then it stops working.
Also the mic unplug seems to repeat itself when I look at the test file:
setting source mic
loopback mic
68
turn off loopback
turn off loopback
turn off loopback
You have to specify a module index or name
Source alsa_input.usb-Logitech_Logitech_USB_Microphone-00.analog-mono does not exist.
70
Failure: No such entity
setting source mic
loopback mic
78
turn off loopback
turn off loopback
setting source mic
loopback mic
80
turn off loopback
turn off loopback
setting source mic
loopback mic
82
turn off loopback
turn off loopback
setting source mic
loopback mic
84
turn off loopback
turn off loopback
setting source mic
loopback mic
87
turn off loopback
turn off loopback
Another weird thing even though it says, "Source alsa_input.usb-Logitech_Logitech_USB_Microphone-00.analog-mono does not exist." It still works.
