I have a hotcorner in the top-left, to show all windows, and in the bottom-right to show workspaces. It's annoying when these keep activating while playing a game. Is there anyway to set Compiz to ignore hot corners when there's a full screen window?
Below two options; one script to disable all hotcorners (temporarily) if your active window is maximized, and one to only disable the specific hotcorners and actions you mention in the question.
Both scripts are extremely light weight and add no noticeable burden to your system whatsoever.
1. Disable all hotcorners if the active window is full screen
The background patch below will disable all hotcorners if (and as long as) the active window is maximized (fullscreen).
The script
#!/usr/bin/env python3
import subprocess
import time
import ast
import os
edgedata = os.path.join(os.environ["HOME"], ".stored_edges")
key = "/org/compiz/profiles/unity/plugins/"
corners = [
"|TopRight", "|TopLeft", "|BottomLeft", "|Right",
"|Left", "|Top", "|Bottom", "|BottomRight",
def get(cmd):
# just a helper function
try:
return subprocess.check_output(cmd).decode("utf-8").strip()
except subprocess.CalledProcessError:
pass
def setval(cmd):
# just another helper function
subprocess.Popen(cmd)
def check_win():
# see if the active window is maximized
# get the active window, convert the id to wmctrl format
windata = get(["wmctrl", "-lG"])
if windata:
w = hex(int(get(["xdotool", "getactivewindow"])))
front = w[:2]+((10-len(w))*"0")+w[2:]
# look up the window size
match = [l for l in windata.splitlines() if front in l][0].split()[4:6]
# and compare them, if equal -> window is maximized
return match == res
def get_res():
# look up screen resolution
scrdata = get("xrandr").split(); resindex = scrdata.index("connected")+2
return [n for n in scrdata[resindex].split("+")[0].split("x")]
def get_edges():
# get data from dump, remember
data = get(["dconf", "dump", key]).split()
for s in data:
if s.startswith("["):
k = s.replace("[", "").replace("]", "/")
elif any([[c in s][0] for c in corners]):
currval = s.split("=")
stored = ["dconf", "write", key+k+currval[0], currval[1]]
tempval = ["dconf", "write", key+k+currval[0], "''"]
open(edgedata, "a+").write(str(stored)+"\n")
setval(tempval)
def set_stored():
# set the stored values
try:
prev = open(edgedata).readlines()
except FileNotFoundError:
pass
else:
for l in [l.strip() for l in open(edgedata).readlines()]:
toset = ast.literal_eval(l)
setval(toset)
os.remove(edgedata)
res = get_res()
state1 = None
while True:
time.sleep(1)
state2 = check_win()
if state2 != None:
if state2 != state1:
get_edges() if state2 else set_stored()
state1 = state2
How to use
The script needs both
xdotoolandwmctrl:sudo apt-get install wmctrl xdotool- Copy the script into an empty file, safe it as
disable_corners.py Test- run the script from a terminal with the command:
python3 /path/to/disable_corners.pyIf all works fine, add it to Startup Applications: Dash > Startup Applications > Add. Add the command:
/bin/bash -c "sleep 10 && python3 /path/to/disable_corners.py"
2. Disable only specific edges if the active window is full screen
The (background) script below will disable both corners actions you mention if the active window is maximized.
The script
import subprocess
import time
key = "/org/compiz/profiles/unity/plugins"
active1 = "'|BottomRight'"; active2 = "'|TopLeft'"
def get(cmd):
try:
pass
def setval(cmd):
def check_win():
if windata:
return match == res
def get_res():
res = get_res()
state1 = None
while True:
time.sleep(1)
if state2 != None:
newws = "''" if state2 else active1
# below the specific edges to take care of
setval(["dconf", "write", key+"/expo/expo-edge", newws])
newspread = "''" if state2 else active2
setval(["dconf", "write", key+"/scale/initiate-edge", newspread])
state1 = state2
How to use
Usage and set up is exactly the same as option 1.
Explanation
- On startup of the script, the script checks the screen's resolution.
- Once per second, the script checks the size of the active window, and compares it to the screen's resolution.
- If the window size and the resolution are equal, the window is obviously maximized.
If there is a change in the situation (maximized/unmaximized), the script sets/unsets your set hotcorners using the commands:
dconf write /org/compiz/profiles/unity/plugins/expo/expo-edge "''" dconf write /org/compiz/profiles/unity/plugins/scale/initiate-edge "''"to disable, or
dconf write /org/compiz/profiles/unity/plugins "'|BottomRight'" dconf write /org/compiz/profiles/unity/plugins "'|TopLeft'"to enable.
- 85,475
