I met the same problem.
system: Linux mint 18.1 "Serena"
When I did like this:
$ sudo apt-get install vlc browser-plugin-vlc
Outcomes:
sudo: unable to resolve host mint
Reading package lists... Done
Building dependency tree
vlc : Depends: vlc-nox (= 2.2.2+git20170601+r59025+56~ubuntu16.04.1) but it is not going to be installed
Depends: libavcodec-ffmpeg56 (>= 7:2.4) but it is not going to be installed or
libavcodec-ffmpeg-extra56 (>= 7:2.4) but it is not going to be installed
I tried many methods that i can search on the net, such like:
$ sudo apt-get update
$ sudo apt-get upgrade
$ sudo apt-get update --fix-missing
$ sudo apt-get autoclean $$ apt-get clear cache
and so on.
But those can help me to solve the problem.
I also see Synaptic Package Manager --> Custom Filters --> Broken, there were no broken package.
Finally, I changed the software source, then I tried
The problem was solved.
