I can only boot into Ubuntu 16.10 with the nogpumanager parameter set.
I'm not too familiar with Linux but I wanted to know if this is affecting performance because I'm getting alot of screen tearing. I have used the latest Intel Update Tool to install the driver however I still face issues in playing simple Youtube videos. My laptop is an inspiron 7559 with a 4k screen.I have set the scaling to be quite large but that doesn't seem to have any effect on video playback.
If I boot without nogpumanager in the kernel parameters I receive only a black screen on startup and I then have to shutdown the system via the power button. What can I do? Is the GPU manager slowing down my graphics performance or is my driver not initialized properly (which I also suspect because of the huge amount of work it took to get it working).
Below is my xorg.conf
Section "ServerLayout"
    Identifier "layout"
    Screen 0 "intel"
EndSection
Section "Device"
    Identifier "Intel Graphics"
    Driver "intel"
    BusID "PCI:0@0:2:0"
    Option "AccelMethod" "sna"
    Option "TearFree" "True"
    Option "DRI" "3"
EndSection
Section "Screen"
    Identifier "intel"
    Device "intel"
EndSection
Section "Device"
    Identifier "nvidia"
    Driver "nvidia"
    BusID "PCI:2@0:0:0"
    Option "ConstrainCursor" "off"
EndSection
Section "Screen"
    Identifier "nvidia"
    Device "nvidia"
    Option "AllowEmptyInitialConfiguration" "on"
    Option "IgnoreDisplayDevices" "CRT"
EndSection
And here is output of lshw:
   description: 3D controller
       product: GM107M [GeForce GTX 960M]
       vendor: NVIDIA Corporation
       physical id: 0
       bus info: pci@0000:02:00.0
       version: a2
       width: 64 bits
       clock: 33MHz
       capabilities: bus_master cap_list rom
       configuration: driver=nvidia latency=0
       resources: irq:17 memory:de000000-deffffff memory:c0000000-cfffffff memory:d0000000-d1ffffff ioport:e000(size=128) memory:df000000-df07ffff
  *-display
       description: VGA compatible controller
       product: HD Graphics 530
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 06
       width: 64 bits
       clock: 33MHz
       capabilities: vga_controller bus_master cap_list rom
       configuration: driver=i915 latency=0
       resources: irq:320 memory:dd000000-ddffffff memory:b0000000-bfffffff ioport:f000(size=64) memory:c0000-dffff
This is now resolved. Starting from the beginning:
  1. Add nogpumanager to your grub boot options.
  2. Install NVidia driver with intel microcode
  3. Set intel to be your graphics card and reboot
  4. Install latest Intel Graphics driver from: https://01.org/linuxgraphics/downloads/intel-graphics-update-tool-linux-os-v2.0.4 (I am running KUbuntu 16.10 Yakkety)
Then reboot and run this in Konsole:
sudo X :1 -configure
If it errors out no need to worry so did mine but it created a new xorg.conf in my home directory.
then:
sudo cp /home/<username>/xorg.conf.new /etc/X11/xorg.conf
sudo nano /etc/X11/xorg.conf
Scroll down to Section "Device" and uncomment the features you want to use and set them to the appropriate value (next to the line is written what kind of values it accepts, ie bool or string).
Here is what I enabled (below is an incomplete xorg.conf only showing the "Device" section. Dont copy paste the whole thing and overwrite the other settings):
Section "Device"
        ### Available Driver options are:-
        ### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
        ### <string>: "String", <freq>: "<f> Hz/kHz/MHz",
        ### <percent>: "<f>%"
        ### [arg]: arg optional
        Option     "Accel" "True"
        #Option     "Backlight"                 # <str>
        #Option     "CustomEDID"                # <str>
        #Option     "DRI"                       # <str>
        #Option     "Present"                   # [<bool>]
        #Option     "ColorKey"                  # <i>
        #Option     "VideoKey"                  # <i>
        #Option     "Tiling"                    # [<bool>]
        #Option     "LinearFramebuffer"         # [<bool>]
        #Option     "HWRotation"                # [<bool>]
        Option     "VSync" "True"
        #Option     "PageFlip"                  # [<bool>]
        #Option     "SwapbuffersWait"           # [<bool>]
        #Option     "TripleBuffer"              # [<bool>]
        #Option     "XvPreferOverlay"           # [<bool>]
        #Option     "HotPlug"                   # [<bool>]
        #Option     "ReprobeOutputs"            # [<bool>]
        #Option     "XvMC"                      # [<bool>]
        #Option     "ZaphodHeads"               # <str>
        #Option     "VirtualHeads"              # <i>
        #Option     "PerCrtcPixmaps"            # [<bool>]
        #Option     "FallbackDebug"             # [<bool>]
        #Option     "DebugFlushBatches"         # [<bool>]
        #Option     "DebugFlushCaches"          # [<bool>]
        #Option     "DebugWait"                 # [<bool>]
        #Option     "BufferCache"               # [<bool>]
        Identifier  "Card0"
        Driver      "intel"
        BusID       "PCI:0:2:0"
EndSection
Section "Device"
        #Option     "SWcursor"                  # [<bool>]
        #Option     "kmsdev"                    # <str>
        #Option     "ShadowFB"                  # [<bool>]
        #Option     "AccelMethod"               # <str>
        Identifier  "Card1"
        Driver      "modesetting"
        BusID       "PCI:2:0:0"
EndSection
If you need to check if its working run
sudo intel_gpu_top
and seperately:
glxgears
You should see the render in gpu_top increasing and decreasing as its being used to draw the gears.
Initial xorg configure command from: https://askubuntu.com/a/151490/607467
