I want to move all the *.txt files from all the subdirectories located in a given directory to one destination-directory.
When doing it as below, it moves EVERY file - how can I reduce it to all the *.txt files only?
find -type f -print0|xargs -0r mv -it "/path to my folder/destination-directory"
Zanna
  • 72,312
Middi
  • 91
Use a glob pattern with -name option of find to indicate the desired pattern, *.txt in your case:
find . -type f -name '*.txt' -exec mv -t /destination {} +
Of course, replace /destination with the actual destination directory.
Notes:
  • You don't need to spawn xargs and an anonymous pipe, use the mv logic within the -exec predicate of find
  • find ... -exec handles all kind of possible filenames and ARG_MAX as well
  • GNU mv (default in Ubuntu) has -t to take a destination directory, so that you can leverage the + argument of -exec to send all files in single run of mv (or at least minimal runs if ARG_MAX is triggered in the process)
heemayl
  • 93,925
Add a -name test
find -type f -name "*.txt" -print0 |...
Don't forget to quote the glob to prevent shell expansions.
For case-insensitive search, use -iname instead of -name
Zanna
  • 72,312
find /folder/ -type f -name "*.txt" -exec mv {} /other/folder/ \;
I tested this, works nicely.
Seth
  • 59,332
Using your original command:
find . -type f -name "*.txt" -print0|xargs -0r mv -it /path/to/destination
Info:
  1. .: search in current location
  2. "*.txt": files that have a .txt extension in their names
George Udosen
  • 37,534
