When I start Chromium the program just disappears shortly after the tabs have loaded.
I have a fresh install of ubuntu 11.10 that I installed it using the wubi installer. Chromium worked fine when I first installed it. Things I can remember doing before it stopped:
  • I installed 200+ ubuntu updates
  • I synced chrome with my google account (bookmarks etc)
  • Installed and removed eclipse
I have tried un-installing and re-installing Chromium but the problem persists.
Where can I look to diagnose the cause of the crashing?
UPDATE - Here's what the console spits out:
matt@ubuntu:~$ chromium-browser
(chromium-browser:2023): Gtk-WARNING **: Unable to locate theme engine in module_path: "pixmap",
[2023:2023:1515592300:ERROR:browser_main.cc(96)] Gtk: gtk_widget_size_allocate(): attempt to allocate widget with width -2147483648 and height 1026
chromium-browser: /build/buildd/cairo-1.10.2/src/cairo-surface.c:1287: cairo_surface_set_device_offset: Assertion `status == CAIRO_STATUS_SUCCESS' failed.
Aborted
matt@ubuntu:~$
Short answer
  1. Start Chromium from a terminal with chromium-browser --password-store=basic
  2. Log in to a web page (in my case, gmail)
  3. Close Chromium
  4. It should now start normally.
Reason
I found the bug is already reported here. My default starting page was the gmail login page (it's password pages that cause the crash). I was able to start the program so that it stays open with the option '--password-store=basic'. Doing this seemed to fix some problem with my synced password keystore.
What will help for many programms in config problems
In cases something really doesnt work u can try not removing but Purging what means deleting also configuration files of programm.
sudo apt-get purge chromium-browser
then try after installing again start and if not still working then delete folder of configuration for that programm for specific user in this case
sudo rm ~/.config/chromium
and then starting should reset all and work.
Kangarooo
  • 5,223
Additionally to remove the
error - try
sudo apt-get install gtk2-engines-pixbuf
Alvin
  • 720
