I am using a Dell Latitude Laptop with a Docking Station. Two displays are attached to it via DVI. I am only working with the external screens the laptop is shut.
Now this is a minor problem, but still pretty annoying. When I go to suspend mode (which I do quiet frequently), the displays go off and then want to login again, the second display is turning off and on every few seconds. When I detach the DVI cable at the docking station and then plug it in again, the problem disappears.
The first display works just fine. Does anyone have an idea how to fix this? I guess you can image, that I don't want to plug off and in the cable, every time I'm going back from suspend.
EDIT: It seems this is indeed caused by the Docking Station. Maybe there is a problem with the Linux drivers, but someone at work told me, he has similar issues with his windows machines. I have found even more display and suspend bugs since then, I think my Dell hardware just doesn't go well with Ubuntu.
