How do I avoid installing the recommended packages and suggested packages along with upgrading the packages when I apt-get install a particular package?
Zanna
  • 72,312
samhitha
  • 187
Suggested packages are not installed by default, to install suggested packages you need to explicitly use --install-suggests option (or set APT::Install-Suggests yes apt configuration parameter).
Now, to avoid installing Recommended packages, either use --no-install-recommends option with apt-get or set APT::Install-Recommends "0" in anyplace referred by Dir::Etc::Main (typically /etc/apt/apt.conf) or Dir::Etc::Parts (typically /etc/apt/apt.conf.d/.
Similarly, to avoid upgrading packages, either use --no-upgrade option with apt-get or set APT::Get::Upgrade "0" in anyplace referred by Dir::Etc::Main or Dir::Etc::Parts.
In a nutshell, with apt-get:
sudo apt-get install --no-install-recommends --no-upgrade <package_name>
heemayl
  • 93,925
In other to install a package without the recommended packages is to run the install command with the --no-install-recommends option like this:
sudo apt-get install --no-install-recommends package_name
Don't upgrade packages:
sudo apt-get install --no-upgrade pkg_name
Don't install new packages:
sudo apt-get install --only-upgrade pkg_name
--no-upgrade:
Do not upgrade packages; when used in conjunction with install, no-upgrade will prevent packages on the command line from being upgraded if they are already installed. Configuration Item: APT::Get::Upgrade.
--only-upgrade:
Do not install new packages; when used in conjunction with install, only-upgrade will install upgrades for already installed packages only and ignore requests to install new packages. Configuration Item: APT::Get::Only-Upgrade.
So to achieve what your asking:
sudo apt-get install --no-install-recommends --no-upgrade pkg_name
Source: man apt-get
George Udosen
  • 37,534
