I installed the the lamp server on my machine and installed wordpress on it and it work ; the problem when I upload files to the wordpress through the control panel of the wordpress no files uploaded because the permission
I found a terminal lines used before and they succeeded in a lot of times but this time they can't make any sense
so I though about to make change the files place from var/www to my normal partitions so I will not face any problems with permissions
Any help , please ?
First of all, go through this about changing your apache root directory to another drive.
Now you have to give permission to all users to upload files on your server in the present root directory.
Run the following command to give permission.
sudo chmod 777 /path/to/upload/folder.
After that you will be able to uplad files on the desired directory.
