I am currently using Ubuntu-gnome 16.04 LTS with "Greybird" theme for both, GTK-2 & GTK-3 applications. I really do like the theme, but I would like to modify it with regards to color-behaviour in nautilus (see below).
  • (1) change the 'background' (???) color (currently #e3e3e3) behind non-selected folders and files in the folder-pane to the same one as the bg_color (#ffffff)
  • (2) change the background (currently #dae0e6) in the side-panel, since it is hardly readable...
(1) 'grey background' behind all folders and items; (2) bluish-grey background in sidepanel
So I was looking into any *.css file of the theme, but albeit trial-and-erroring a lot, I was not able to identify the respective lines.
[My problem is NOT 'how to' modify a theme in general, but 'what' to modify in this particular case.]
Hints for which lines to look for would be highly appreciated. Thanks in advance.
LUser
  • 184
  1. Unfortunately I still have not found a way to change the view background of items (currently #e3e3e3) to the theme base_color (#ffffff), instead tough I was able to apply the color vice versa. To do this I had to add following line in the themes gnome-applications.css file:
NautilusWindow .view {background-color: #e3e3e3;}
  1. To adjust the side-panel to my likes I made the following changes in the themes gtk-widgets.css under the /************ sidebar ************/ header:
..sidebar GtkScrolledWindow { background-color: mix(shade(@theme_base_color, 0.9), shade(@theme_selected_bg_color, 1.35), 0.1); color: mix(@theme_text_color, @theme_base_color, 0.15); -gtk-icon-style: symbolic;
....and...
.sidebar-row:selected:focus { border-width: 1px 0; border-style: solid; border-top-color: shade(@theme_bg_color, 0.85); border-bottom-color: shade(@theme_bg_color, 1.12); background-image: linear-gradient(to top, shade(mix(@theme_base_color, @theme_selected_bg_color, 0.7), 1.05), shade(mix(@theme_base_color, @theme_selected_bg_color, 0.7), 0.97) ); color: #ffffff; }
The result can be seen here: Greybird theme modified for nautilus file manager
LUser
  • 184
