On Ubuntu 16.04 a machine I've installed VeraCrypt 1.19. When I'm trying to open an existing container I get the error:
"No such file or directory: dmsetup"
veracrypt::process::execute:108
I created it on Windows 10 on a NTFS partition - but I don't think that's the problem.
I've tried the sudo apt-get install dmsetup thing, but that doesn't work.
Thanks in advance.
karel
  • 122,292
  • 133
  • 301
  • 332
Dekker
  • 61
I did
according to this post. It started working after that.
blue_chip
  • 161
I have the same problem and solved it. What I do is checking the "Do not use kernel cryptographic services" then it works.
go through with :veraCrypt >> Settings >> Default keyfiles > Tab-[System Integration]
[System Integration] > Kernel Services : "Do not use kernel cryptographic services" (<--- check it)
Good luck!
qoop
