I have ubuntu installed in a VM run by VMWare Workstation.
I was able to increase the size of the disk via VMWare Workstation to 70Gb (which I see on the line Disk /dev/sda: 70 GiB) but I cannot figure out how to resize the partition to use this space / expand the filesystem (dev/mapper/vagrant--vg-root 35G 31G 2.5G 93% /: this still is 35G)
What should be the next step? (via the command line) Thanks
t@test:~$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 2.0G 0 2.0G 0% /dev
tmpfs 396M 9.9M 386M 3% /run
/dev/mapper/vagrant--vg-root 35G 31G 2.5G 93% /
tmpfs 2.0G 4.0K 2.0G 1% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup
/dev/sda1 472M 190M 258M 43% /boot
tmpfs 396M 0 396M 0% /run/user/900
t@test:~$ sudo fdisk -l
Disk /dev/ram0: 64 MiB, 67108864 bytes, 131072 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram1: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram2: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram3: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram4: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram5: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram6: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram7: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram8: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram9: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram10: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram11: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram12: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram13: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram14: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram15: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/sda: 70 GiB, 75161927680 bytes, 146800640 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x58bce432
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 999423 997376 487M 83 Linux
/dev/sda2 1001470 83884031 82882562 39.5G 5 Extended
/dev/sda5 1001472 83884031 82882560 39.5G 8e Linux LVM
Disk /dev/mapper/vagrant--vg-root: 35.5 GiB, 38138806272 bytes, 74489856 sectors
Disk /dev/mapper/vagrant--vg-swap_1: 4 GiB, 4294967296 bytes, 8388608 sectors
