So I have a really stupid problem: I followed this tutorial (Drawing over the desktop) and accidentally mapped the "Initiate line" hotkey to mousebutton 1, which means that left clicks are no longer registered and all that happens instaed is that I draw a green coloured line on my desktop that stays until I reboot my pc. I was wondering if there was a way to fix this issue using only terminal, which is pretty much the only application I can use right now. The graphics interface of compizconfig-settings-manager is pretty much completely inaccessible now.
Thanks in advance!
From the CCSM Main screen (click) Preferences -> (click) Rest to defaults.
After making changes you can save various configurations and use this same screen to restore to a working configuration. This way if it becomes unusable again, you won't have to back all the way back to the defaults. You can restore a previous configuration.
Many of the settings under CCSM can be found in the Unity Tweak Tool. Install this to gain control over the corrupted settings:
$ sudo apt install unity-tweak-tool
This command will get restore most of the defaults:
$ unity-tweak-tool --reset-unity
You may have to run the command unity to load the new settings.
L. D. James
  • 25,444
