I use ubuntu 11.10. I've tried to install nautilus action-3.1.5 with the software centre. It's been installed but doesn't start at all.
Then i've tried to install nautilus action-3.1.5 from source but when i do
./configure --with-gtk=3 --with-default-io-provider=na-desktop --disable-gconf
there is a problem with gconf:
checking for GCONF... no
configure: error: GCONF: condition gconf-2.0 >= 2.8.0 not satisfied
The same error's signalled if i do the simple command ./configure without paramethers. What can i do?
Jorge Castro
  • 73,717
It will build fine on 11.10, you need to install libgconf2-dev
Jorge Castro
  • 73,717
doug
  • 17,212
This is a bug , just check the link https://bugs.launchpad.net/nautilus-actions/+bug/822282
Solution:
a fix for this, you must download the latest source from http://www.nautilus-actions.org/downloads/ and compile it with option --with-gtk=3 . It will work
sum2000
  • 1,276
