When I run /usr/bin/click, I get the following error:
Traceback (most recent call last):
File "/usr/bin/click", line 37, in <module>
import click
ImportError: No module named 'click'
I tried to reinstall package click, but I got the same error during installation:
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 0 B/14,7 kB of archives.
After this operation, 0 B of additional disk space will be used.
(Reading database ... 255715 files and directories currently installed.)
Preparing to unpack .../click_0.4.45.1+16.10.20160916-0ubuntu1_amd64.deb ...
Unpacking click (0.4.45.1+16.10.20160916-0ubuntu1) over (0.4.45.1+16.10.20160916-0ubuntu1) ...
Processing triggers for ureadahead (0.100.0-19) ...
Setting up click (0.4.45.1+16.10.20160916-0ubuntu1) ...
import click
dpkg: error processing package click (--configure):
subprocess installed post-installation script returned error exit status 1
Processing triggers for man-db (2.7.5-1) ...
Processing triggers for shared-mime-info (1.7-1) ...
click
I have already removed another package click, which comes from pip3, but it didn't help. It seems that either required files (I believe that their source is here) are absent on the system or python cannot find it.
So the questions are: where python package click should be located, and how can I fix the error.
