Brief: Is there a way to install rabbitmq-plugins via a ubuntu package?
Details:
I have rabbitmq running ok in my ubuntu system, and now I'm trying to monitor what's going on via the management plugin. I'm following rabbitmq.com/management.html instructions, but can't execute
rabbitmq-plugins enable rabbitmq_management
because my system does not have rabbitmq-plugins installed.
It's Ubuntu 11.10, and came with rabbitmq installed as a package (aptitude install rabbitmq-server librabbitmq-dev). The config and the server are running fine (the installed version is 2.5.0).
Thought that the plugin would get installed by installing "sudo aptitude install rabbitmq-plugins-common", but doing that does not install rabbitmq-plugins.
Is there a package that will install the plugin? I'd like to avoid if possible having to purge the rabbitmq server that is running ok, and then reinstall it via a download + build from source, all just to get the plugin.
Jorge Castro
  • 73,717
jd.
  • 133
Update your /etc/apt/sources.list with the latest rabbitmq distribution
deb http://www.rabbitmq.com/debian/ testing main
Jorge Castro
  • 73,717
Dave
  • 76
1st edit your /etc/apt/sources.list as above, then add the key to your your trusted key list. you can find the needed command in following link. Link: http://www.rabbitmq.com/install-debian.html
