I followed the mainstream instructions for installing Ubuntu 16.10 alongside windows 10. After installing Ubuntu I restarted my computer to get the GRUB menu to choose which OS to boot. Everything is fine. Booted Ubuntu 16.10 and then I wanted to test Windows as well, so I shut the pc down and turned on again to find the same menu but this time I chose Windows. When I turned it on again, it just ignored grub and went straight to booting Windows.
EDIT: Windows 10 fast start and hibernation are disabled, Secure Boot is disabled; my notebook is a Sony Vaio SVE151J11X
EDIT2: through admin prompt on windows i just ran:
bcdedit /set {bootmgr} path \EFI\ubuntu\shimx64.efi
now everything is fine. Thanks
Zanna
  • 72,312
You could try try update-grub, or booting off the live USB or Livecd and running install-grub /dev/sda with the hard drive mounted. This will reinstall GRUB and should check for other operating systems again.
Otherwise, install and use Boot-repair from a live session.
sudo add-apt-repository ppa:yannubuntu/boot-repair
sudo apt-get update
sudo apt-get install boot-repair && boot-repair
check this: Grub2
Or add this to sudo update-grub2
Another option add in /etc/grub.d/40_custom this:
menuentry "Windows" {
set root=(hd0,2)
chainloader +1
You might need to twiddle the numbers to get the right partition.
To try the last thing you have to know your Windows 10 parition.
so open bash..
sudo update-grub2
vi grub.cfg
** change the lines I have marked with ** # <--- change this** in your grub.cfg.
and then..
sudo grub-install /dev/sda
