I have an installation of Ubuntu 16.04 on a Raspberry Pi 3 with rbenv installed properly already. I'm trying to install nginx/passenger (integrated version) on it, but the following is happening.
user@pi:~$ sudo apt-get install nginx
[sudo] password for user:
Reading package lists... Done
Building dependency tree
nginx : Depends: nginx-extras (>= 1:1.10.2-8.5.1.2~xenial1) but it is not going to be installed
Depends: nginx-extras (< 1:1.10.2-8.5.1.2~xenial1.1~) but it is not going to be installed
When I try to install nginx-extras manually it tells me the same about nginx-common. I've installed nginx/passenger on several Ubuntu systems but haven't run into this before - might be Pi related? I've seen lots of links of people having this issue from 9 months ago but I'm not sure why it's still occurring.
I did a sudo apt-get update && sudo apt-get upgrade today just in case. Still nothing.
None of the answers I've found work for me.
I initially added the steps for this answer (which is on the original how-to I followed, except using a passenger source entry for Xenial). I get the above error when I do that.
I then tried this answer but it installs a standalone nginx version which works, but doesn't have Passenger integration.
edit: Definitely on xenial: cat /etc/os-release gives me
NAME="Ubuntu"
VERSION="16.04.2 LTS (Xenial Xerus)"
I don't consider this a duplicate since this is an issue that seems to be specific to the Raspberry Pi 3 hardware. I have installed nginx/passenger many times on non-Pi machines, virtual machines, linode instances, etc etc and never had any issues like this. I may be wrong of course!
