I am going to install Xubuntu 12.04 LTS as it has a non-pae kernel that I need to get it to run on my old PC. Is there any way I can update everything other than the kernel once I get it installed?
Zanna
  • 72,312
In this Q&A (Blocking kernel updates with dpkg) the OP was also on Ubuntu 12.04 and had to hold the kernel at a specific version because things break when upgrading.
A short summary of the link:
First check your kernel image name
dpkg -l | grep linux-image
output for the poster:
ii  linux-image-3.2.0-4-amd64              3.2.35-2                           amd64        Linux 3.2 for 64-bit PCs
ii  linux-image-amd64                      3.2+46                             amd64        Linux for 64-bit PCs (meta-package)
then tell dpkg to hold the metapackage (the generic version without any version numbers)
echo linux-image-amd64 hold | sudo dpkg --set-selections
You can then check this worked via dpkg -l linux-image-amd64
Please read the entire question and answer before proceeding.
