"Sorry, an error occured and it was not possible to install the bootloader at the specified location" After I bought I brand new 1tb HHD to install Ubuntu on. Any ideas? (Dual booting with Windows 10)
This issue has brought misery and woe to many, myself included. The causes and solutions seem to vary slightly. The solution I found is not quite ideal but it ended up working.
In my case, I was able to find success after using boot-repair to try to install the bootloader again. I ran boot-repair in the non-UEFI Ubuntu from the LiveUSB instead of from the UEFI version. I have a feeling similar success is possible after making an EFI partition but I was a little wary after I ran into a lot of trouble in this adventure. At one point my computer kept freezing at the BIOS splash screen. I think it was because Windows tries to "repair" the LiveUSB disk which puts it in a state that my EFI/BIOS had trouble with.
My Windows 10 is on a dynamic disk and I learned that the bootloader wasn't going to be able to be installed there. However, boot-repair was able to install it onto the disk that Ubuntu is on, which is what I was trying to do with the installer both when it first asked about the disks and later in that error window.
With this setup, I have to select the disk I installed Ubuntu on in the BIOS menu when the computer starts up. Grub shows up when I select the disk with Ubuntu and I'm able to boot into the OS, however I'm not able to get into Windows from any of the two selections it shows. Instead, I have to use the BIOS menu to select the disk that has Windows. This works alright, but I might try the UEFI boot solution when I'm feeling adventurous again.
- 101
- 2
