I have little space in my home directory and plenty of space in my Windows partition that I don't use very much. I'm trying to move this space to my home directory.
It currently looks like that:
df -h
Filesystem Size Used Avail Use% Mounted on
udev 3,9G 4,0K 3,9G 1% /dev
tmpfs 789M 1,8M 787M 1% /run
/dev/sda5 46G 40G 4,1G 91% /
none 4,0K 0 4,0K 0% /sys/fs/cgroup
none 5,0M 0 5,0M 0% /run/lock
none 3,9G 56M 3,8G 2% /run/shm
none 100M 16K 100M 1% /run/user
/dev/sda7 48G 45G 806M 99% /home
/dev/sda4 324G 31G 294G 10% /media/myUser/00FABDE2FABDD3DE
/dev/sda3 107G 77G 31G 72% /media/myUser/F05C219E5C216118
I want to move space from /dev/sda4 to /dev/sda7.
I tried using:
sudo mount /dev/sda4 /dev/sda7
Mount is denied because the NTFS volume is already exclusively opened.
The volume may be already mounted, or another software may use it which
could be identified for example by the help of the 'fuser' command.
What's the correct way?
