I have qtsixa installed but it is no longer of use to me. I didn't use apt-get so I can't remove it using that. any way to remove it?
Even though you say you didn't use apt-get or apt please try this method incase you did.
First, open a terminal by doing Ctrl + Alt + T
PPA purge, not only removes the PPA but also uninstalls all the programs installed by the PPA.
Install ppa-purge by using the following command:
$ sudo apt-get install ppa-purge
Now use it in following manner to purge the PPA:
$ sudo ppa-purge PPA-URL-HERE
The URL of the PPA for qtsixa can be found in the Software Sources list.
The ppa url should be, 'ppa:falk-t-j/qtsixa' according to, 'https://help.ubuntu.com/community/Sixaxis'
If that did not work, then you might have compiled it. You can remove the program binary by using which to find it.
Example(For the bash program. You shouldn't remove bash.)
$ which bash
/usr/bin/bash
Now that you know where the bash binary is located you can remove it with rm. Example:
$ sudo rm /usr/bin/bash
You should be able to follow the same steps to find the qtsixa binary.
- 71
