I have an rtl8814au WiFi chipset that I am trying to get to work with Linux:
- I have tried downloading the file (.zip) then
- Going in the terminal and changing directory the one that contains the file and then
./ (filename)to run.- I get permission denied error so
I tried
chmod +x (filename)then./ (filename)again and got the error below. I have almost no experience with Linux other than installing it and update and upgrade so any help is greatly appreciated.root@Graybox:/home/kryas/Downloads# ./rtl8814AU-driver-4.3.21.zip ./rtl8814AU-driver-4.3.21.zip: line 1: $'PK\003\004': command not found ./rtl8814AU-driver-4.3.21.zip: line 2: $'\273\201QI\030': command not found ./rtl8814AU-driver-4.3.21.zip: line 8: syntax error near unexpected token `)' ./rtl8814AU-driver-4.3.21.zip: line 8: ��QIf����G rtl8814AU-driver- 4.3.21/LICENSEUT2[X�\[s�ȱ~�:?bJy�TE�k�$'�Nm%Q�RH�^�$�"b`0�d����e�/�ŕ�- �����ח��������7u��'���4~��\��$��<K�.]��;�����- �lg~'��oGK�W�*u%��{���y���b�U����{�������a�1���J���г�sg����{к*��2}^W������eoJ���XU�I��MQ�ˤ�����>����b����N���IW���dEQ��e�+"�y`�O���������������+wK�ݺr�V�[ڪ� ph�|i����t^W��+��fC_��[�l�ƛ*2�,�b�Y<o�$N�g�VD>/*�dY���}s����%�y������ޮ��n���T迥��s.�V�7|���쮨K��ņ��k~�`^�˪o��ȫ2�`��Z��e�z��4�\�����r�pF����R�� <�}�G6ħ��-�lKг�Q�<z[{�M�$�zsB���6�)��,> O���9���i�q��)m�lnQ@o ���aߥ�2)w�l:�}��e��ڧ���$����0âW�=N�(X���]n_!حK��4X���}E�n�ʒ� ��H9Ͷ����=����^|�IEZa�ɋ�p�����g�Uw�gVÆ5x��6]i����E�Y' root@Graybox:/home/kryas/Downloads# cd /home/kryas/Downloads/rtl8814AU-driver-4.3.21.zip
