I am dual booting Ubuntu 16.04 and Windows 10 but am having a sporadic issue.
GRUB will show up, and if I boot into Ubuntu, it works fine. If I shut down from Ubuntu and restart, everything works great.
However, after I boot into Windows 10, shut down, and reboot, the GRUB menu does NOT appear. Instead I am greeted with the Minimal BASH-like line editing is supported message:
Minimal BASH-like line editing is supported. For the first word, TAB
lists possible command completions. Anywhere else TAB lists the possible
completions of a device/filename.
The only way for me to temporarily fix this issue is if I boot Ubuntu from my USB stick and run the boot repair. It claims it has fixed the boot menu/GRUB, but the process above continuously repeats. Booting into either OS works, but specifically after shutting down from Windows 10, the Minimal Bash message appears.
I tried this command from Windows 10 but it does not appear to have changed anything:
bcdedit /set {bootmgr} path \EFI\ubuntu\grubx64.efi
I am booting in UEFI mode with SecureBoot mode disabled and have an Acer Aspire V7-582P-6673 if that helps.
Try with the live session, on the USB or cd, to reinstall grub-efi. Open a terminal and enter the following commands:
sudo mount /dev/sda# /mnt
Replace the hashtag in /dev/sda# with the number representing the partition where you had Ubuntu 16.04 installed. You can use gparted to do it.
sudo mount /dev/sda# /mnt/boot/efi
Replace the hashtag in /dev/sda# with the number representing the efi partition. It's usually /dev/sda2.
sudo mount -o bind /dev /mnt/dev
sudo mount -o bind /proc /mnt/proc
sudo mount -o bind /sys /mnt/sys
sudo mount -o bind /run /mnt/run
sudo chroot /mnt/
sudo apt-get install --reinstall grub-efi
sudo update-grub
reboot, to realize if it works.
